Older st criox
DirtDog
6
East
I just moved in to a new home and the house has a older St Criox prescott model . Analog controls not digital. I manually start the stove but i cant get any hot air to blow out. I have changed the high limit swtich and still hasnt helped . When i would press the manual feed button before it would sometimes kick the blower on but now nothing. I have cleaned it out and it hasnt helped. Could it be the low limit swtich ? Any help would be great .
thanks adam
There was a Prescott I and the Prescott II. The Prescott II with modifications is what is being sold today. On the digital models the proof of fire snap disc is used to turn on the room air blower.
Steps to trouble shoot it. Unit on
1) Check voltage one side of snap disc and the neutral on the blower. 110? Yes Step 2, No bad wiring harness or bad board
2) Check for power at blower. Power yes? bad blower Power no? Step 3
3) Unplug unit. Remove snap disc. Heat snap disc and check for continuity. No continuity replace snap disc
Manuals
(broken link removed to http://stcroixstoves.com/pdfs/Pellet%20Manuals/Prescott-Scandia-Afton-Somerset-Bayport%20Manuals.pdf)
(broken link removed to http://stcroixstoves.com/pdfs/Other%20Manuals/Analog%20Control%20Board%20Manual.pdf)
Hope this helps
Brad
