I'm finally installing my 1980s Jotul 118 (w/5") opening.
Saw a few threads regarding single/double wall and still not sure what to use .... since draft/length of pipe seemed to be a factor in the decision. Trying to save some $$$...
durock w/1" wall spacing is in place behind the stove and extends up the wall/roof rafters to reduce clearance.
I'll have between 5 and 6' vertical from the output of the stove and where the black stove pipe will terminate into the roof support. From there I calculated I'd need ~10-11'+ of triple wall above the roof.... so total run will be around 15-17' which exceeds (meets) the manuals recommendations.
I've got the 5-6" adapter on hand...and right now my proposed install will consist of the adapter connected straight to the stove followed by a 6" 90 degree elbow and then straight up to the support box.
It seems single wall will suffice?
I may get two 36" lengths and toss a damper in between, but haven't done the research yet.
