My parents have a 1978 hs tarm mbsolo. They used it 1 year had a chimney fire and never used again. At any rate I was looking through the book on it and I recall a optional swing out oil burner door to go in place of the wood door so that you could burn oil or switch back to wood.. Has anyone ever heard of this or can anyone verify this? I am going to put a wood hot air furnace in my home and have gas heat now
I was thinking of oil/wood combo or add on and wondering if it would be possible to rig up an oil burner in the wood furnace door. My reason for this is that I found 500 gals of good oil buried in my yard in a tank and every once in a while I get a deal where I can have oil if I want to pump it out of someones tank that is leaking or converting to gas.... Any ideas?
![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
