Hey Folks - Im a newbie here and have read alot of great articles !!
I have an older American Harvest 6039 Pellet stove in my garage I use when out in the man cave and tuning in toys, came with house and garage when i purchased house. Stove has been running great last 2 winters with only having to do a cleaning when needed. Couple weeks back fired it up and went into house while garage warmed up, went out a while later to smoke every where in garage.. after all cleared tried to fire back up and didnt seem to be running at full potential like it has been so looked at stove and some forums, noticed seal around window in door was leaking so replaced the seal and cleaned out fire box, still wasnt running properly or to the full potential of what me and my buddies are use to..
basically when you first start it flame is great, once she gets going ill put her to 9 - 9 ( like i always have from day one when she gets warmed up, and never had any issues at all ) and flame doesnt seem to be where she was at.. we would turn stove down to 4-4 and fire would go out so we messed with it a bit by adding in our own pellets in hopper and stove would be ok with normal size flames.. so decided to shut it off and clean EVERYTHING and found some spots ive never cleaned before ( behing fire box and to plates and it was nasty) cleaned and blew out pipes and all motors in back, re fired and did same thing, we would add pellets and seemed to be ok so started thinking auger motor kicked the pail, call AH and they said lack of pellets - auger motor is going bad.. well just put in the new motor last night fired it up and auger is deff running better and feeding more pellets then it was but still dont seem like it use to run earlier this yr or last winter.. stove will now stay running on 4 -4 but no matter if its on 4-4 or 9-9 the flames just dont seem to be at full potential still seems like weak flames ( flames barely taller then fire box itself) there is NO DRAFT lever below door either FYI.. This thing has me and my buddies baffled and banging are heads against the wall and i dont wanna keep throwing parts at it for no reason... Always have and been running NEW ENGLAND Hardwood pellets through cuz thats what i buy for my Harman inside the house...
Any thoughts or suggestions on what could be going on here
Many thanks in advance before i drag this stove down the street behind my truck !
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
