Hi fellas. I havent used my Eko controller to start my pump in quite a while. I thought I would give it a whirl again today, and now I remember why I gave it up. It likes to break the Eko fuse. It was OK when I plugged my pump (011 taco) in while the boiler was up to temp, but sure enough when the temp dropped it cut the pump as it should, then when it bounced back up to heat it blew the fuse. Im I running to big a pump on it? Without this feature, it is much harder to restart from a consumed fire.
I plan to get the newer controller for next season. I hope this does not also happen on the newer controller.
Oh, I use a 2 amp? fuse. Would installing a bigger fuse be a mistake?
