Good morning.
I have a 200 year old house. It has 4 unusable fireplaces in it. 1 may need to be disassembled. Also one large one doesn't even have a damper at the top of the firebox. Here are pictures and dimensions to start it off as well as some info on my plans.
I currently have a Harman pellet furnace that I installed in my basement to heat my top floor and a few bottom floor rooms via ducts. I like this product and would like to stick with this brand if possible. My heat load calculation for my house shows me losing about 35-40k BTU out of my chimeneys alone per hour. Obviously I want to fix this, but now I am tryign to decide how. I want to still use the fireplaces with combination of wood and pellets. The idea of fixing my drafting/heat loss problems while adding a heat source seems great to me. Also I have the challenge of not losing the old charm of the house. I am generally trying to get all cast iron matte black finish products to match the house.
Currently all the chimneys are unlined but are massive. I plan on lining all chimneys with an insulated Stainless steel flex appropriate to each appliance (each will have its own).
The fireboxes:
Dimensions: 32w x 46.5h x 22d (top) 25d(bot) (20w at rear)
I plan on putting a Harman Accentra inside this space. I will use it as a spot heater for that room. If the heat travels to the neighboring hallways, that will be a bonus. I chose this appliance because I like the harman products, and my furnace downstairs uses the same parts. Also, I do not want to lose the details (pot arm, etc.) of this old kitchen fireplace by covering it all up.
The next photo is a fireplace off the same chimney, adjacent to the last fireplace. This one our inspector told us is junk. It is in a wierd spot which will most likely be a future hallway. I am on the fence about what will happen to it.
Dimensions: 37w x 31h x 15-12d (bot-top) x 28w at rear
This next Fireplace is in the current kitchen opposite to the 1st in the list and adjajent to the one listed directly above. It uses the same chimney. It is fairly wide and has no damper to shut it off from the outside unless I can call cardboard from costco a damper. This is a Fireplace that I would use as an insert to burn wood. It would only be situational/ambiance. The bonus is that I would be closing it up properly to avoid heat loss and be able to create heat with the same solution. I want to go with wood here in case of an outage. There is also an old gravity heat transfer grill directly above it so heat can get to the 2nd floor.
Dimensions: 44w (32.5 w at rear) x 32.5h x 19.5-17.5 d (Bottom-top)
This last fireplace is my biggest dilemma.
Dimensions: 33w (16w at rear) x 26h x 13-11.5d (Bottom to top)
I would really like to put a Harman Accentra pellet insert in this fireplace because I am often too busy to tend to a fire these days and again would like to stick with Harman. Though, I am not totally opposed to a wood insert. Here are some products that may fit that fireplace if I must go with wood: Lennox country performer, Avalon Ranier 45, Regency H2100, Lopi answer. This list is a sampling that I have been able to find so far. This particular fireplace is very shallow at only 11" at the top and 13" at the bottom. But the current dimensions do not allow it. Also the surrounding cast iron block off plate supplied with most appliances is too large, I do not want to block off all of the old woodwork.
So, my questions are:
Can I enlarge that opening?
The depth will need to gain 5" to be safe. The width in the rear will need to gain 10". A plan of this house and a few measurements taken show the wall behind face of this central fireplace to be 36". So, somewhere inside there there is alot of space.
Anyway, is there a reason not to do this if I had the space and the structure of the chimney is not affected?
Can I trim down the surrounds that come with most of these products if I maintain the clearances recommended by the manufacturer?
I would need to tailor this to each opening. I can do the ironwork/metalwork. Is there a safety reason I cannot do this?
I am trying to supply as much information as possible along with some eyecandy to look at. Hopefully this is enough to give me your 2 cents.
Thanks,
Matt
The fireboxes:
Thanks,
Matt
