I have an old blue/white Homelite XL12 that a friend gave me not running. I cleaned the wood chips out of the carb and then it ran fine. Now I am having a new problem with no fuel flow. The diaphragm in the carb is OK, but it appears the gas line is clogged. I pulled the rubber line off the copper hard line going to the tank, and tried to blow air through. Nothing. No bubbles, and plugged up tight.
Is there a seperate pump/diaphragm in or at the tank? Will it only pass fuel if the engine is turning over?
To get to the side of the fuel tank, I have to pull the clutch, and I do not have the tool to remove it. It's frustrating, because it is still a good old saw with good compression. It cut great as my backup saw a couple of weeks ago when I wrecked the chain on my Stihl.
Thanks for any help keeping this old iron going.
![Mad :mad: :mad:](/talk/styles/default/xenforo/smileys/angry.gif)
