Check this old cast gas "insert" out.
http://philadelphia.craigslist.org/atq/1679220088.html
and this one too:
http://philadelphia.craigslist.org/atq/1664627579.html
Another Humphry Randiantfire
http://philadelphia.craigslist.org/atq/1683915184.html
Are these serious safety problems? Like an old gas range that required a constant pilot? And if the pilot goes out, your house could blow up? Could this problem be avoided with a modern gas valve, or some type of safety valve?
The reason I'm asking...
I'm wondering if anyone has any of these that are still functional. It appears that they'd need to run vent free. The reason I believe so is because I bought a house that has a really nice stained wood mantel with a slate-type stone which is made to look like brick tile, which itself is really pretty ugly. The setup is on a brick wall with absolutely no possibility of having a vent or chimney nearby, but you can see the plugged hole in the floor where it appears a gas line previously came up through the floor. So I imagine that most likely there was a gas log of some type in this 100 year old home.
We've now got electric heat pumps, and absolutely no backup heat in the event of a power outage. I'm considering my options to get some backup heat that would require no electricity. My research started with looking at inexpensive wood stoves, but I installed a gas vent free fireplace in the past, and realize this could be the perfect option for this house, whether I put one in the basement I'm getting ready to finish, or one where I believe there previously was one on the first floor, or maybe both.
I think I'd opt for a newer unit that has safety controls, and would be much less likely to leak gas. However, it might be cool to restore the first floor fireplace to it's original glory if there's any chance of this not being a safety issue.
Thanks!
Mike
Found some info on a google search for "Humphrey Radiantfire"
http://chicagoantiquesguide.com/archives/20051025190734.php
and this one too:
Thanks!
Mike
