Hi, All! I recently bought a used Englander 25-PDV, and it's not the basic model. Let me tell you what I know:
Manufactured date is 05/00. Serial # is WHI-009653
It looks like the standard 25-PDV, has brass louvers on the front, 4 heat exchanger tubes, door handle is closed down and on the left.
Where it gets funny is in the burn pot area. (see pics) There is no removable burn pot, never was, and as near as I can tell, there is not a place to put a wear plate. I'm assuming that you just pile some pellets in front of the auger and light'em up. Does anyone have experience with this style of 25-PDV? No manual with this configuration is available that I can find.
As far as the other parts of the stove go, the exhaust fan works, both the top and bottom augers work, the control board SEEMS to do what it should, but I won't know until I fire the stove.
So, some additional questions:
Is there a way to test the combustion blower without firing up the stove?
I see there is a place to connect a thermostat to the control board. Should there be a jumper there?
There is not a pressure switch on the stove, and I can't find a nipple on the exhaust fan housing, so maybe this unit never had a pressure switch. Is there a way to install a pressure switch on the existing fan housing? I do like some safety with my heat.
There is no feed adjustment door between the hopper and the top auger. Is that a really bad thing, or just sorta bad, or not bad at all?
Lastly, what amp fuse do you think the previous owner installed in the control board? (see pic) I'm guessing 100,000.
This stove needs all new gaskets, at the very least. Maybe many other things. I'm not in it deep dollars, and I'd rather quit while I'm behind IF the burn pot is a really bad design.
All thoughts appreciated.
