- Dec 12, 2006
- 60
Hello, new member here from northern california. This is my first post. I am in my first house that uses wood stoves for sole source of heat. I love cutting, hauling, splitting, stacking and sitting in front of with a beer and burning wood in my wood stoves.
Here in northern california, you can get permits from the Forest Service to go into the forest and cut firewood. It's 15 per cord with a maximum of 10 cords. That is just a little tidbit about where I live, but has nothing to do with my question.
Here is my situation:
I have a two story house. It has a gambel roof (shaped like a barn), the upstairs celing has open rafters and the downstairs is a daylight basement.
There is a brick chimney that is right in the center of the house and it runs from the lower level, up through the main level and out the roof. Inside this chimney there are two seperate terracotta liners. One is for the stove that is downstairs (an old trail blazer) and one is for the stove that is upstairs (a new country s160.
Each stove has an elbow that comes right off the top of the stove, goes into a hole in the brick chimney, that goes right up that stoves flue.
The downstairs stove will heat the entire house if you burn the heck outta it, but I like to have a fire upstairs when we are home.
The new stove upstairs will draft enought to get and keep a good fire going, but when I open the door to put more wood in, I can only open it about 1/4 of the ay at the very most before I get some smoke coming out.
What I would like to do is replace the two terracotta flues for each stove with a rigid SS stove pipe. It seems to me I could go up on the roof and ust up and extract the two old flues and then proceed from there.
Am I crazy?
Anybody have other suggestions?
What questions (like dimensions and the like) would I need for you guys to help me get started on this?
Thanks for the help
Am I crazy?
Thanks for the help
