OK folks, I'm confused.  What am I doing wrong?
In another topic I posted that I'm having difficulty in maintaining a decent temperature, and that I can go from full flame down to red glow in around two hours. This is making it quite difficult to leave the stove for any length of time and maintain a heat.
OK, the facts:
I am using seasoned mixed hardwood, have a stainless steel lined 12m chimney and as far as I can tell a good draft (it is always easy to start the fire). The stove is a 7kW, clean burning Morso Owl, and I maintain a reasonable bed of ash wherever possible. The stove has three air controls - one at the back (which is factory set and therefore can't be adjusted), and two at the front (the left one brings air from below, and the right one is the airwash).
What I do:
I get the stove up to temperature, which is normally between 400F and 500F depending on the amount of wood I put in it. I keep both air inlets fairly open until I have reached these temperatures, and progressively close them down - generally trying to close the left hand inlet down more than the right hand one (so that the airwash keeps the glass clean). I find that the temperature then drops over approximately an hour down to around 220F, and I have to put more wood in. I have found that the more wood I add, generally the hotter the stove temperature but no general increase in burn time is seen.
What I don't do:
I never close down both front inlets fully - I have found that what can happen when I close the inlets too far is that the flame firstly changes colour to a red/purple colour, and then eventually appears to go out (but is quickly reinstated by opening the lower air (left inlet).
Taking for example my most recent burn, on Sunday night: I managed to get a stack temperature of 520F, using five moderately sized splits (12" mainly) but having reached that temperature and closed down the air intakes most of the way, that dropped back to a red glow and ~250F in less than two hours.
Bearing in mind that I am still a relative beginner to all of this, and bearing in mind that my Owl is a 7kW stove (and therefore not huge) how should I be using it (assume I have the stove up to temperature). How many splits should I add when reloading, and how do I maximise the burn without ending up with a sooty window? How does my technique compare to that of you seasoned wood-burning types? Am I doing something wrong?
Any and all help *much* appreciated.
John
OK, the facts:
What I do:
What I don't do:
John
		 )  But I digress...  If I put in 2 very large peices of wood such as elm, or oak, I easily get burn times and usable heat up to 8 hours.  A much more controlled and even burn too.  I learned a lot about splitting wood and how big a chunk to throw into a stove.  In my opinion, and in almost all cases, the larger the split, the better off you are.  Sure it takes longer to season, but in the end, you'll get better results.
