OK...just what is a side arm?
muncybob
2,159
Near Williamsport, PA
I've read where folk with OWB use a side arm for hot water...what are they talking about? :question:
Type sidearm in the search box. You will be amazed ;)
A sidearm is a gravity-activated heat exchanger that is typically attached to a hot water heater to provide domestic hot water. When you pump hot boiler water through the outer shell, it causes the water in your water heater to circulate through the inner tube, eventually heating your hot water heater up to the temp of the boiler. In the fall I shut off my electric hot water heater and don't turn it back on until the end of the heating season. We have an unlimited supply of domestic hot water through the entire heating season.
Here's a basic diagram. If you're halfway handy with a torch and solder, you can build your own for around $100 in materials.
  • [Hearth.com] OK...just what is a side arm?
Thanks for the thumbnails..exaclty what I wanted. Now the results from the search feature makes more sense to me.
