I am ordering the chimney liner for the Summit insert.
26' from top of clay liner to existing fireplace floor.
Looking at this:
5 pc 6" dura liner double wall insulated rigid @ 4' each = roughly 19'6" after deducting laps.
extend a cap kit, includes cap, top plate, storm collar and clamp.
5' of 6" dura flex from rigid to insert, will set close to mid first clay tile liner after smoke shelf.
straight 6" stove adapter.
I might get a pc of 2' rigid also, to make sure I get out the top of the chimney.
I want the rigid in where I can get it. Its insulated so no need to mess with insulation & mesh.
My question is, Do I have to insulate the flex?
Remember, it will run from insert to roughly first clay tile above smoke shelf, connecting then to the insulated rigid.
I would rather not insulate the lower flex if not necessary. That's roughly another $200.00.
I will be making a block off plate (smile Elk, you've made an impact
)and trying to get some approved insulation for above it. Any suggestions & where to purchase?
Looking at this:
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
