Hi everyone,
Had a bit of a scare last night and I'm hoping someone has some tips, suggestions, ideas. I loaded up the stove for the night about 9:45 (7 total splits, 4 smaller, 3 larger). Stove temp was hovering around 300 at the time as it was mostly coals when I loaded it. Let this catch for about 15 minutes with air full open, got stove top temp to around 400, and closed the air to about 1/3. Left it that way for another 10 minutes and temp went to 500. Fully closed primary air control. Within the next 30 minutes the secondary kicked in and my stove temp went to roughly 800ish. Maybe 810. I've got a video posted here to see the secondary burn when it was running about 700. Shortly after the video was made it climbed to 800. I put the blower on high and opened a window. That brought the temp back down to 700 in about 20 minutes. I didn't really want to run the blower last night as it wasn't that cold out.
http://video.yahoo.com/video/play?vid=48f5b4213f11c1908b61215d4e2540db.1521614
So my question is what could I have done differently? I'd prefer to keep my overnight burns around 500 and not flirt with the 800 range on a regular basis. Stove manual states over 800 is over-firing. I know I could put in less wood, but then I wouldn't get the overnight burn either. I literally felt like there was nothing I could do to control the temp. The stove took it from 500 to 800 without me touching it. Should I close the air off sooner?
My middle secondary burn tube was literally glowing bright red. The stove top never really started to glow red so I know I wasn't heating the steel quite to that point, but I felt it was close. I guess I thought I'd have a little more control over the temp of the stove by using the primary air control...
Thoughts, ideas, suggestions?
Eric
Eric
