Doocrew said:
lass442 said:
Here's a question for those of you who have base board hot water/oil heating systems, but heat primarily with pellets. Do you make it a habit to turn your oil furnace thermostats on once in a while to move the water through the pipes? If so, how frequently? What are your reasons?
I'm in the same boat Lass. I have a tankless hot water system so my furnace is kicking on several times a day for showers. On occasion, I will turn on a zone to let the water circulate. I also turn up the heat in the basement family room once in a while because my pellet stove is on the first floor.
This is good. On occasion, you mean once a week, once every couple of weeks? To me, common sense would prevail at once every few weeks, depending on outdoor conditions. For example, we have a one car under garage with a family room over it, so opening up the first floor thermostat to let it flow once the outdoor temp reaches 20 for 2 or 3 days might be a time to let her rip. I wouldn't think that twice a day is necessary. Would you?
Last night I came in when it was pretty cold outside. The second floor was downright chilly, so I turned on the oil. Worked out nicely all the way around, kept me comfy and ran water through the pipes.
