For Sale Oil furnace (& AC) parts: Burner, pump, manometer, Smoke test, fan timer, etc
paulmars
67
fl
Im replacing my furnace with air handler.
Beckett afg f3 burner w\ new nozzle & new pump. Includes 1 or 2 extra never used nozzles and the perfectly working old pump. New pump & nozzle have less then 1 hour use. pumps: a2va-7116 & 7116B.
200$ w/o used pump. 250$ with both pumps.
Bacharach Smoke tester & 2 packs of papers. 100$.
orbital flare tool bought new in 2022. 50$
Dwyer model # 400-5 most accurate monometer (more accurate then any digital gauge). No carry case. 100$.
ST9103A electronic fan timer. 75$.
R8184 G originally came with burner 75$.
about 40' new never used oil supply line copper tube tubing. Ends capped. 25$. Piping
Gauges, as shown free with all above.
Fuel filter housing w\ 2 parker shut offs(not shown). Filter contains new filter & includes several extra new never used filters(shown). 2 extra filter housings never used(shown) Housings and filters free with all above. used one with shutoffs cant be shipped. Pickup only.
extra high temp sheet gasket material. free with all above.
ask for more pics.
Buyer pays shipping or pickup in st pete florida.
Burner installed new 2003 in florida. So, not used a lot. Not used at all when I was away at work or sleeping.
two years ago had problem and chamber became very sooty. Cleaned everything up, but kept getting air in line. Replaced some of the tubing and the pump, after replacing nozzle. Nothing worked. Two years later Im burned out and getting a heat pump. So burner really dont have a lot of hours on it. I think electrodes are pretty new too. Aslo have extra set of electrodes.
The smoke tester I bought new 10 years ago and only used it to tune this heater. So, it's basically in new condition. I accidentally bought an extra set of true spot test papers.
Dwyer I bought as surplus. It had dried fluid it in. An engineer at Dwyer told me how to clean it out. It has a few cracks in it as purchased, but none breech the fluid area. Both air connectors were totally blocked and Dwyer told me I could just drill them out, as long as gauge is not laid down it is fine. Connectors allow air in either direction but stop fluid. Still I bought two new connectors, but never installed them. Uses red fluid is A-101.
ST9103A electronic fan timer, bought new in 2010 because original failed.
