sparke said:
Agreed, I plan on keeping the oil boiler connected in tandem. Hopefully we will hear from folks that have this system. Thanks for the input.
Sparke... Glad to hear from you.
Got any pictures of that Buderhus wood/coal unit???
I run coal/wood boiler also. "In theory" you could be "oil independant". When I set my boiler up that also "was a goal"...you could do it...people have. My "best year" was less than 150 gallons (not bad when you consider an average heating year I use 1100 gallons without wood backup).
As to the 'spirit' of your question...is your question strictly 'can it be done' or is part of it you wonder "should I run it every so often"???
...One thing to keep in mind, generally a 'warm' boiler lasts longer according to some. Whether it's from the fire inside the unit or just "circulated through" not a bad idea to keep it warm occasionally.
Depending on how big of a tank you use to store the heat...will determine "how often you have to fire". A local here in my neck of the woods can regularly go 3 days without firing his boiler.
In my locale, I no longer have this option "for the summertime" as wood firing is excluded from 5/15 to 9/15 by local ordinance... there are some 'stealth burners' though...lol
Is your buderhus a 'gasification unit' by any chance???
There are a few 'boiler burners' here and I'm sure they will also chime in.
Heat storage is a great option you should definately look into... do some searching here on the site.
When you say your "older boiler"...which one?? Terminology is the key (boy could I get web going OWB-Oil water boiler...lol)... For "discusion purposes" and to make things easy...when you are talking about either of your boilers (ain't it great to be able to say..'yeah I got two of em'..) refer to your wood/coal as the 'SFB' (SOLID fuel boiler)...makes thing easier all the way around...
Once again...glad to hear from a fellow 'boiler burner'.....
