twitch said:I'm not sure if I saw this link on the forum, or if the company is still around, but it's worth a look. I think this is the kind of thing you are looking for.
http://www.pellergy.com/default.html
pybyr said:Perhaps you could contact Maine Pellet Systems to see if you could buy one of their burner heads by itself.
Sting said:Keep the oil boiler for a back up and install an under sized pellet boiler - call both to service on those one or two coldest nights,
Hansson said:Sting said:Keep the oil boiler for a back up and install an under sized pellet boiler - call both to service on those one or two coldest nights,
why? You can change back to the oil in a few minutes. 2 boilers wold have a massive heat loss.
I wonder why people in the US have so hard to give up the oil
Hansson said:You cant convert all oil boilers to pellets. The pellets burner must have some more room for the fire than a oil burner.
You also have to remove ash more frequently whit pellets.
For backup we only use electricity here. Burning oil is a big no no
Sting said:Hansson said:Sting said:Keep the oil boiler for a back up and install an under sized pellet boiler - call both to service on those one or two coldest nights,
OUCH! My fingers got slapped for a lucid suggestion!
Funny how folks from Sweeeden are so quick to judge.
Ashley said:I used a Swedish Pellx 20 Kw in my Buderus G115 boiler last winter. I put about 6 tons of pellets through it and managed to keep warm. I found that I have to clean it about every 800 lbs of pellets, depending on the quality.
Here they have done that. Oil heating is to expensive .It have bring up som new ways to heat you home.rowerwet said:Unless politicians see a way to dump outrageous taxes on a technology (the carbon tax) the cheapest will be the one that sells the best.
