karl said:
Thank for the info Hog. They have been out of the bag for awhile, but I'll lay them on the driveway for a few days. As far as the door adjusment goes, I don't see anyway to adjust it. The hinges are welded on. The handle has P E's new roller thing on it, and the latch is the only thing with a bolt on it and it's screwed all the way in. How do I adjust the door, and how do I know if it needs adjusted? As far as the 12-14 hour burns. Is that for real? I thought 8 or 9 was the norm with stoves. This one included. Also, when you added three feet to your chimney, how high did it make it?
OK Karl, good questions. and here are your answers
Door dollar test:
Take a decent dollar bill or any bill. open door, putt part of the dollar bill in between the door & the stove, close door on said bill. Gently pull on bill, I also tried to slide mine sideways. Do this all around the door. If the bill pulls out or slides side to side with no resistance, adjustment is needed. In my case the lower portion & the side the door latched on was very loose. It took me a couple weeks to discover this and fix it. The bill should not move, or be very hard to move. If it moved easily or freely time for the next task.
Door adjustment:
The latch is the only place for adjustment on a PE. The latch you see bolted to the stove itself can be adjusted in, by tapping on the top open part, slightly bending it inwards. This is achieved by tapping the latch in with a small block of wood & a hammer, or a mallet, or if very careful, just a small hammer. Block of wood or mallet keeps finish from marring. Re test with dollar bill, and adjust further as needed. Keep in mind, when stove is cool & when stove is hot, the door adjustment will tighten & loosen a lil from the metal expanding & contracting. I did all my testing & adjusting while stove was cold for obvious reasons.
On all PE Summits as I and a few others in here discovered last year. The metal framing lip on stove that the door gasket closes against, is slightly bowed out in the center. We all ran straight edges along the upper & lower edges to discover a slight bow. I came to the conclusion that since we all had this, the factory intentionally did this probably to form a tighter seal on door by the slight bow creating pressure on an axis point. Don't remember for sure, but I believe they previously to this had problems with leakage along middle or one side and it built up with creosote. Maybe this was to remedy that. I could be wrong and my memory playing tricks on me
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
But the two steps up top are the way to test & adjust a PE.
As far as 12-14 hr burns. I think it may be possible. But IMO, to consider a 24/7 constant length of burn, 8 hrs or maybe a lil more is reasonable. I have had a couple longer burns, and yes even at 14 hrs or longer, you will have coals to restart a fire. If you figure a little lower in length of time, the rest is just a bonus. All depends on what wood type, how its packed in, and how its burnt. Look up the cigar burning method by Roospike in here and that is a very long burning method.
Off to look at a couple wrecks, see yall.
