oldspark said:
Thank you your reply and I am running it EXACTLY like you typed. The way I run my new stove for the most part is from people on this site which except for a few I trust.
It was icy on the roof this morning so I should have waited before I posted and this post would not have happened, some condensation (I guess) mixed with some fine creosot on the new chimney cap and ran down the side of the chimney, once I got on the roof I could see it was mostly frozen water with a little black mixed in, there is some black dusting of creosote which I am going to sweep after work today.
I never had any creosote with my old stove what so ever so am surprised by the dusting this early. Once again thanks for taking the time to reply.
Edit-By the way I have NEVER had a darkened glass door.
Dear Fellow Rule Bender:
From the trenches of wood burning in one of the more Northern regions, done for many, many years, with more steel and cast and stone fireboxes than one can count, here's the scoop on wood burning.
Relax, enjoy the appliance. You'll get the hang of your particular box in time. Hey, it's an art. Using a wood stove is not like programming in C+, or setting up a web site in HTML for a client, doing a colonoscopy, or even using Semtex; it's learned behavior to tame whatever beast you've chosen to use as heat.
This is a tough time of the year to learn---it is the shoulder season (not the NFL kind Sparky ). The fires need to be small, short, and hot; too often damped down when there's too much heat. It's a good time to use that "junque" wood such as softwoods you usually throw to the side. Spruce, fir, pines, cottonwood, popple all have less density that the hardwood species we like in northern N.America.
Ah yes, the "glass" issue: leave it be. I'd rather be enjoying my favorite beverage than cleaning . The rule that you read here is frankly B.S. You heat with wood, any wood, in any EPA stove with a CLEAR CERAMIC door (ain't "glass" BTW), for any amount of time for heat, you will damp the air, ergo blackened clear ceramic. It will go away with the next hot or normal fire. Of course, if you enjoy cleaning, scraping, fussing, fiddling with the stove, by all means clean. It will keep you out of your significant other's hair.
Some unburnt debris will collect on the coolest part of your fleu: the top. It's normal. You don't ever want that thick, shiny, gummy junque collecting however. Be careful up there.
Now, you may read the more "trusted", appointed experts here who religiously (it is a religion of OCD) monitor their appliances with IR meters, M² devices, probes here and probes there, digital video tools stuck up the flue,
and they will tell you the 'correct' way to burn with Excel spreads, but all that is secondary (as in secondary burn) to what you want: HEAT.
Enjoy the ride.
JMNSFHO
