OAK. Is it worth it in my case?
Dmitry
1,219
CT
I have used free standing Osburn 2400 . I'm planning on installing it in my walk out basement . It has big masonry fireplace and stove is going there. I'll use it for karaoke and drinking nights . It's away from above ground wall and run will be really long. Do I want to go trough the hassle if will be using stove dozen times over the winter.
P.S. There is a big masonry chimney , but I understand you can't install OAK along with your liner. Right?
If the stove needs it to operate properly yes. If it doesnt probably not
Can I install OAK along with liner trough the chimney?
An OAK cant be routed in elevation above where it enters the stove, unless it is a passive connection. It must be level or lower. Stove could reverse draft and blow flue gas out of it. If only a few times a year, maybe just crack the door or window a tiny bit in the basement when burning....and drinking.....and singing......
