Greetings!
I'm hoping someone may be able to help me with my NTI Trinity 150 questions. I've been experiencing issues with my propane boiler for close to 4 years now.
I've invested thousands in local heating contractors only to find purchased parts that were not necessary and no solution.
Boiler make/model:
2008 NTI Trinity 150 boiler system.
Here's what's happening:
The boiler continuously cycles for about 30 seconds at a time and then I receive a ACS ER3 code. Only luke warm water and temperature will not exceed 64 degrees.
During this process, the flame "eventually" lights after several cycles and stays lit for about 30 to 60 seconds before throwing the ACS ER3 code.
We've had multiple, certified technicians come out to clean it and troubleshoot. Each time a part was replaced and no solution..I have kids and we just want to be warm.
Here's what's been replaced:
• Flame Sensor
• Flame Rod
• Flame Probe
• Sentury control panel.
• Inducer motor
• Expansion tank
• Watts Air Vent
None of the above has solved the primary issue listed above. We typically have enough hot water to last for 30 minutes at a time and when really cold, we set the thermostat to 68 degrees, but the room won't heat beyond 64 degrees.
Any ideas as to what the issue could be? Can you offer any insight or tasks that I can do myself to try and resolve?
I'm attaching a link to a YouTube video I created a few years ago that demonstrates the issue. (See below)
The other issue...I created myself, I replaced the expansion tank and drained about 5 gallons of water and introduced air into the pipes. No I just need to know which Spigot is for draining, and which levers to pull to isolate and then re-introduce water.
I'm currently between 12-15 psi and heat water flushing through my hot water baseboards. Here are a few pictures of my set up. We run propane and have a well.
![NTI Trinity 150 Hydronic Boiler issue. NTI Trinity 150 Hydronic Boiler issue.](https://www.hearth.com/talk/data/attachments/323/323729-4f0432624500e0d2a451393a5fe25b50.jpg)
Boiler make/model:
• Flame Sensor
• Flame Rod
• Flame Probe
• Inducer motor
• Expansion tank
• Watts Air Vent
![NTI Trinity 150 Hydronic Boiler issue. NTI Trinity 150 Hydronic Boiler issue.](https://www.hearth.com/talk/data/attachments/323/323728-665379a9394a7f75a7c1df0af0ccc0f2.jpg)
