Hello all! I have been burning the Dovre Aurora #700 since 1993 so not much has changed lately, but for some reason this season at times I will notice more of a smoke smell inside the house when I am starting the stove on a cold start. The chimney is not blocked, the amount of creosote when I checked right before the season was so insignificant that I didn't have to clean it, but I did clean the first 4.5 feet or so because I took that section off to check to make sure that the elbow wasn't rusted through, even had a guy at the stove shop look at it and he said it was fine, so it isn't creosote and what was lining the upper part just looked like dust, no glaze because I burn hot with good dry wood. The only thing that I did differently was I adjusted the bushing that the door latch closes on, I felt it was a little tight so I made it so it closed looser, but it was such a small adjustment that I doubt it did anything much to the gasket on the door when it closes, and as we know even if it did that would allow more air IN not allow anything out unless it was a huge backpuff. I even several times in the dark got a flashlight and looked around the stove door and the sides and the back and checked the stovepipe but saw no smoke coming out, and I have small pieces of gasket stuffed in the gaps where the pipe meets too. But for some reason I at times on startup notice more of a smoky smell, unless it is coming out when I open it towards the beginning to add some bigger pieces once the kindling and quarter splits get going and I'm just not noticing it? Like I said I am basically doing everything the same since 1993, just smelling a bit more smoke smell, and I know the draft and weather can play games with it but tonight the draft was noticeably strong as it is clear and cold out today, we are supposed to get up to a foot of snow the next two days, don't know if that has anything to do with it? The only thing different is the door latches a little looser, but that wouldn't be an issue would it because I'd see smoke coming out and again it is drawn in?! I am starting to put the logs a little bit back farther in the firebox, maybe that will help, but once it gets rolling there is no more smoke smell.
Thanks for any input!
