I purchased a house last winter with a preexisting flue. I’ve just had it cleaned and inspected, and apparently all is good. I’m looking at getting a pellet stove this weekend, either the Summer’s Heat 55-SHP22L or the Summer’s Heat 49-SHCPM, the new mult-fuel model. I know they have different pipe rating requirements. Englander told me I can just use a chimney adapter and use the existing flue instead of lining the whole thing, but I’m not sure how to proceed. There are 3 rings of pipe and ring is made up of two layers of metal with no space between them, 14”, 12”, and 8”, the 8” shows signs of use. I can’t find any markings to indicate its model or manufacturer. I don’t know where to go from here or how to connect the pellet stove pipe, just to the 8” and use a cover or ring around it? Any help would be greatly appreciated. I’ve included pictures to try and clear things up a bit, thanks.
*Note: The bright white in the picture is the cement wall inside my house that the flue is behind.
