Northstar by Northern Tool and other thoughts.
jlove1974
245
Piedmont of NC
I am still in the process of shopping for a splitter. I took advantage of the snow days yesterday and managed to check out a few.
I am still lusting after an Iron and Oak, but thought it would be prudent to check out Northern Tool since it looks like they updated their splitter line.
First impression: These things are built RIGHT! Full-length industrial I-beam. Build in log-tray for horizontal splitting purposes. These are all heavy 600+lb machines. 2" ball couplers.
I am not too crazy about the curved-top wedge design, but it has the optional 4-way bolt on wings and really...they are bad@$$. Cast steel wedge has grease fittings on bottom follower.
The 30-ton is probably worth the extra coin over the 22, but much slower since the cylinder is bigger. It has a Honda GX vs the GC on the 22-ton. All Honda horizontal shaft engines.
The 37-ton has a 16GPM pump and a 5" cylinder. It's the hoss I was eyeballing yesterday. They didn't have a 30-ton in stock. Probably the one I would buy based on value vs build quality.
The log dislodger/wedge guard is 5/16" welded steel and looks bulletproof. It covers the entire wedge when the ram is retracted.
Here's the kicker: The NT manager told me that they manufacture them in-house now, and that he had toured the plant where they are build.
Dunno if this is bs or what, but he seemed sincere enough. He told me during demo days that it would be 10% off (sometime in spring).
So the lineup looks like this:
$1399 22-ton 11GPM 2-stage barnes pump Honda GC160 (5hp) 13-sec cycle time looks to be about a 4" cylinder w/ a 1.75" ram. 8 gallon reservoir
$1599 (on sale now for $1519 now) 30-ton same pump Honda GX 17-sec cycle time 4.5" cylinder 8.5 gallon reservoir
$1899 (on sale now for $1799) 37-ton Honda GX270 14-sec cycle time 5" cylinder 9 gallon reservoir
the 4 way wedge part 1143 is $79
I saw one of the 22-tons used on CList for $1250 w/ the 4-way already installed. It has less than 10 hours on it total. For that I'd buy new...
So based on the price and the options, I would seriously have to choose hard between a 37-ton Northstar and a 22-ton Iron and Oak. Subtract 10% but add 7.75% sales tax, or
have the Iron and Oak shipped to residential and add the liftgate fee. Add in the options on the Iron and Oak (log dislodger and wood-tray is optional on these) and I would say
the Northern Tool splitters are up there with the best build quality for the money spent.
I also looked at the Speeco/TSC splitters and I'm not really that impressed. They are cheap, and have a lot of value but I hate the horizontal shaft engine on the 22-ton.
Even northern tool says on their website "Horizontal-shaft engines can expect a lifetime that is up to five times longer than the lifetime of a vertical shaft engine"
Guess that's why the comparable TSC 35-ton has a horizontal briggs engine for $1799
Also, I went to Home Depot rentals and salivated over the rental Makita saws. None for sale, however they did have an old speeco splitter w/ a honda engine for sale. $800,
and the last rental BENT the slots on the beam splitting sweetgum. I laughed. The rental manager said he had a brand new beam for it in the back, and would install it before he sold it.
Gives some food for thought eh? Anyhow, that thing was ragged, and that $800 would be better served being paid toward a new splitter w/ warranty
ah the kicker of it all is that the Northstar is actually mfg'd in China. Designed, engineered and tested in the states....contrary to what the NT manager was telling me.
Also, no hydraulic filter like all of the other splitters I have seen. Whisky Tango Foxtrot?
Now the dilemma of it all is do I want to support the further devaluation of the dollar and support offshoring? I am pretty good at buying American. This might be a hard choice!
No more choice. The 26-ton Iron and Oak has the same 16GPM pump, with a 4.5" cylinder.
Built in Illinois. Powered by a Briggs Vanguard 9hp.
$1999 at woodsplitters direct, although I am thinking about patronizing my local dealer...
Wonder if he will price match?>) ;)
Hello, Bought the NorthStar 37ton a couple of years ago and it is a serious peice of equipment for processing firewood. It has split everything I have ever tried to split and I love Honda engines. My vote is for the NorthStar.
I have the Iron&Oak; rated at 34 ton. Horizontal and vertical. Honda engine. I like mine just fine, never been able to find a knot it will not go through.
I've never used a Northstar splitter, but I do know that TSC is discounting the 35-ton Huskee model to $1699 this week in my region. I purchased mine at that price and got an additional 10% off (coupon) in 2009. Very pleased.
I spent weeks shopping around checking specs like you. But it just comes down to personal preference. My 35 ton Huskee is 4 years old now and I'm still happy with my choice. Here are some things I learned after owning one and seeing others in operation.
A 3 second difference in the full length cycle time doesn't mean much because you don't need to use it all most of the time, but even if you are ripping full length through a gnarly round of elm it's not that big of deal.
A 12-13 HP engine burns a lot more fuel than a 5-6 HP.
There is not much a 35 ton splitter can do that a 22 ton splitter can't.
Big Bad 30-x ton splitters are just Cooler than wimpy 20-x ton splitters. :coolsmile:
Just get the one you like, whichever one it is should last you many years.
Just my $0.02 .......... well $0.002 if you figure in the economy.
Just wanted to point out that the Northstar prices are with the units not assembled.
(I've been lusting after them for years.)
I saw one of the 22-tons used on CList for $1250 w/ the 4-way already installed. It has less than 10 hours on it total. For that I’d buy new…
From the original post (above).
I've NEVER seen these on CL used. If it's in good shape, I'd be all over it.
the honda engine is good but you pay for it. I do believe honda makes good stuff as my accord has the original engine and auto trans and has just under 381,000 miles and I drive it every day.....
I own a Northstar 32 ton horizontal splitter. This thing is a monster and very well built and very tough components. I would buy another one. 4 way wedge is a must!
This is on craigs list. Neighbor needs to know what I think before he buys it. Any thoughts?
$700 Log Splitter Vert or Horiz $700
Towable
Horizontal or Vertical operation
Runs flawlessly
Oversized base
Aftermarket 6.5 H.P. Honda engine with about 20 hours of operation
Standard engine is 5 H.P.
See NorthStar Horizontal/Vertical log splitter on the net for comparison
Retail for this item is about $1400.00 plus $400.00 shipping.
  • Northstar by Northern Tool and other thoughts.
Towable
Runs flawlessly
Oversized base
I'd still buy a $999 22-ton Huskee model at TSC. You'd get all new components, full warranty, higher beam (saves your back), built-in log cradle, beefier log dislodger, et al. And you can get it for 10% off, too, when opening a TSC credit card or with TSC coupon.
Towable
Runs flawlessly
Oversized base
Ya that's one of the older Northstars that my friend has. Retail for $1400 and you get a heck of a better machine now than the older models. Just have to pay
sales tax. That being said, a OLD beater rental SpeeCo at home depot rentals was gonna run me $800. I think not!
I have the iron and oak 26 ton with honda engine, great machine. I looked at the northstar, but they are built in china. Iron and oak has good support for their products. I have found nothing as of yet it will not split.
I just bought a used Iron & Oak (the 20-ton fast cycle model, it has an 8 second cycle). Looking forward to using it. Heard only great things about these splitters.
I have talked to several people on the phone from this forum about the Iron & Oaks and what I say is if you can afford an Iron & Oak and you can still pay your bills then go for it. :)
Second to none in quality, parts are easy to get if needed, 30 years of American built splitters and your supporting our economy. Iron & Oak just rolled out their new 3 point splitters both hydraulic and PTO versions and they look to be a pretty slick unit where its full adjustable and can lower right to the ground for the big heavy rounds you can just roll up on the beam. Also a 4 way wedge will be optional, 9" high x 20" wide. Good Stuff!
Mike
Are there pictures anywhere? I would like to see how they lower it to the ground.
