Hi, noob here but been lurking for months and found great info here at Hearth, so ty for sharing. I've got a couple questions that I hope you all would weigh in on:
1) How much skill is needed to DIY a woodstove install?
I've watched a few videos on the install process including stovepipe & chimney, read folks experiences here, ... some people say they don't ever use their dealer/installer again except to order replacement parts. The closest dealer spitballed a $1k-2k figure for install -- but we're having him come out to give a firm estimate b/c it sounds like his # is low. The stovepipe, chimney, non-stove parts plus labor look more expensive than $1k-2k, so I fear the dealer is only giving a parts OR a labor #, not a total install #.
Also: these stoves weight a ton!! How do DIYers actually move them onto the hearth?
2) Avoiding problems by doing it right the 1st time: poor / excessive draft, backpuffing, overfiring, etc.
I've read a few manuals by the manufacturers and read posts here on how to avoid problems like poor draft / starvation, "jet engine" draft, overfiring. It sounds like a couple things should be done at install to help prevent these:
a) total draft should be at least to spec (so length from stove to cap)
b) avoid 90 degree elbows
c) avoid reducers in pipe
d) keep pipe inside home as much as possible (avoid external chimney)
e) outside / fresh air kit
Wouldn't points (b) & (d) get rid of installing the pipe to an external chimney going through a side wall with thimble? Even though manufacturers allow that in their install manuals. So best option is to install straight up through the roof?
Are additional dampers in pipe, like in the chimney connect / stove pipe, and/or the fresh air intake pipe, recommended? I'd think installing more dampers could help fine tune draft if there's a "jet engine" problem. In Wisconsin, we get strong winter winds from the SW ... thoughts on dealing with draft and winter winds?
3) Is now the time to buy new??
Won't manufacturers be liquidating non-EPA 2020 stoves this year? The local dealer seemed to be hinting at discounts coming. In the previous round of EPA requirements -- was it 2015? -- did manufacturers dump their inventory of stoves that didn't meet the new EPA requirements? If not, is end-of-winter still the best time of year to get discounts on new stoves?
Hopefully the above questions are not too much for a noob![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Justin
Justin
