We just installed out wood burner in our cabin this weekend (602 Jotul, air intake wheel on door, no glass). Chimney runs straight up through cabin, no offsets. This is my first time running a wood burner and have a few questions.
I have a damper installed in the stove pipe about 18" from the stove top. Can someone explain to me how the primary air inlet and the chimney damper work with one another during a burn?
When I get the fire started how do I know if it is burning well enough to close the door and adjust the air inlet? I think I may be shutting the door too soon before it really gets going. I don't want to get the stove too hot because everyone says that these little guys can get away from you.
Finally, when I look through the openings of the air inlet in the door while the fire is going what should I see? Rolling flames, slow flickering flames? I do know that this thing drafts! With the air intake open all the way with a fire going, the draft sounds like a gas forge! I of course shut the down the intake almost all the way, but not sure if I am shutting it down too much.
Thank you in advance for all your help and input.
