Howdy fellow wood burners. Just had an experience that totally freaked me out that I need some feedback on.
Bought a house up here in the "North Country" of New Jersey (Hewitt) in February. House came with a pre 1988 VC Vigilant, which to my amateur probings seems to be in pretty good shape. It clearly was not used as primary heat (There's oil fired hot air furnace here also.)
I've been planning to use wood as my primary heat source and I've been studying and using the stove a little bit (to warm to crank it up) with no problems. seals seem good. The fires I've been doing have been uneventful, including a couple of overnighters (about five hours).
Last night we dropped below freezing for the first time. I had been burning it with small two split fires all day with nothing unusual.
Time for me to go to sleep so I loaded the baby almost full, let it rip for about 10 min. with the damper open and then closed it and headed for bedroom on same floor.
Short while later I /smelled/felt/not sure what/ that something was up with the stove. Temp in the main room with the stove was 80+ degrees and as I approached the stove the floor (not the tiles the stove is on) three feet from the stove was to hot to stand on in my bare feet.
More frighteningly the thermometer on the chimney pipe was just short of being pegged at it's highest reading of 900 (excuse me)
friggin' degrees!
I quickly closed the secondary air cover. The damper handle was immovable (heat expansion?). I had a pot of water I tossed on the fire and after a few minutes I started to spray the fire down with a spray bottle of water every few minutes.
The chimney temp fell, thankfully. pretty quickly to about 600 degrees within about ten minutes and as I sit typing about 45 min after the incident the chimney temp reads between 350 and 400 degrees.
First, am I right in assuming this is what is called a runaway fire? And does anyone have any ideas what the heck happened?
i did notice during the day that the goofy and crude looking "thermostat" was stuck pretty far open and trying to adjust it lower (more closed) did not do anything. In my searching the forum about runaway fire there were a couple of posts about a different VC model that had a runaway fire that in the posts was attributed to this really crude looking mechanism.
Rest assured I won't be doing any overnight burns anytime soon. I won't be going to sleep until this puppy burns out!
TIA,
Littlalex
friggin' degrees!
TIA,
Littlalex
. See how good they work!. (seriously, the one time I had to use it they worked very well...honest).
