no power to castile pellets stove
And then give more info if you want people to help diagnose your situation. That's not much to go on.
Reactions: kappel15
Is it plugged in?
there is a reset button on back,not sure if that is it or not.If it's a quad castile.
[Q UOT E="loaderman, post: 2009910, member: 48365"][/QUOTE]
my Augerwasn't feeling well so I took the other out for the second time and then it had no power to the control box
Check fuse check power cord jump snap disc from older no power jump snap this to no power I don't know how to check the control box for power
If you have a manual, locate #3 snap disc and see if it has been tripped. Some have reset buttons, some don't. You can also try to jump this snap disc by jumping the wires together to see if power returns. If for any reason stove got hot enough to trip this snap disc, it shuts power off to stove. kap
No I have a Quadra-Fire castile insert
I was just checking the Auger for Jam
First plug something else into outlet to make sure you have power. Also make sure power cord is plugged in good on stove. Then,unplug stove, pull control box out, and reinstall it. Plug stove back in. Let us know if anything happens. kap
Nothing
