Sitting in room where woodstove is and it is 88 degrees right now at 1015 at night. There obviosely is no need for me to add any wood as stove top is close to 450 degree room more than comfortable. When 5am comes however my stove will only have some red embers-no big hot built up coals that instantly lite off 10 or 15 min set draft and go. I will need paper kindling , you get the story and ready to go about a half hour later. Now before yall go on about moving heat outa the room, I already have two huge celing fans in there and another fan at ground level next room up blowing into stove room-works good and every 15 feet corner fans to help move heat further through house. Point is noone would throw wood on this to make it 95 degrees as it is at my upper limits now. It was a pleasure when I was home last week and able to every 4 hours or so from a small load refill with no fresh startup required. I geuss I will have to wait until those 10 and 15 degree nights where the house will pull down more and I can fill the stove more at bedtime in hopes of big coals in am.
