No feed in Ontario
careerac
3
Ontario
Castile, four years old. Well maintained (though it's rusting). Just replaced the exhaust blower. Everthing works except won't feed any fuel. Exhaust pipes are clean, as are heat exchangers. I tried snap button number two and other stuff in owner's manual. Suggestions? Possible to bypass vacuum switch so I can determine if it is a faulty vacuum switch? Thanks.
Make sure the hose is clear, take a nail or some thing and make sure the connector on the stove is not plugged. The vacuum switch can be jumped, unplug stove, jump, then plug back in.
1. Yes, Castile Pellet stove
2. thanks for suggestion on cleaning stove connector. how do I "jump" the vacuum switch?
Unhook both wires and connect them together anyway you can, I use a jumper with small alligator clips. One way is cut off a piece of old extension cord, strip the ends of a short piece and jam it into the connectors. If you are not sure of your skills maybe a friend or relative with DIY skills can help you.
