If it was an interior chimney, that would be ok, but an exterior chimney wants to give that heat away. The colder it gets, the more you want that heat. But the more your chimney wants to give it away. Your chimney is very generous with your money.Chardler said:If anything, it warms the masonry surrounding the liner.
Jags said:Why would you NOT want to. Give me one good reason. 'nuff said.
sonnyinbc said:Jags said:Why would you NOT want to. Give me one good reason. 'nuff said.
Here is a good reason. When I went to bed last night the rec-room 15x26 was 88F. I really don`t want it any hotter than that. Exterior chimney,full liner and chimney cap, no block off plate. "And no, I wasn`t running the bear wide open last evening"..
Oh, and the temp outside was 37F.
I think the key word is need. I've talked with two sweeps and two installers in the past few months - none wanted to do blockoffs. I think because it's optional as far as code goes, and is a custom job for each install, there is little interest. My impression is that guys give a quote for a liner install and are looking to get it done asap, one shot. If they're trying to put in the stove/insert and also have a block off ready at the same time, and things are a bit off with whatever offset the liner and insert has, you could be talking about a return trip to the job site. Heaven forbid.buckeye said:My installer too said that I didn't need a block off plate.
iceman said:i hope that you guys without the block off plates at least have the liner insulated (unless its interior)
then you should stuff the bottom (damper opening) with kaowool or something
woodzilla said:iceman said:i hope that you guys without the block off plates at least have the liner insulated (unless its interior)
Right on iceman. 50 bucks off of eBay and you have an instant soft block off plate. With enough left to insulate around insert or seal surround panels. Or share with fellow wood burner. Works great!
Jerry_NJ said:My new Quad insert doesn't have a block off plate, but I can say neither did my old "slammer" ... and it heated the house well. I expect the new insert with a SS liner and cap at the top to do a lot better. This I will have to learn by experience.
Still, the block off plate seems worth considering, but as "handy" as I am I don't even have a set of tin-snips. What's needed to make a block off plate out of sheet metal, and where do you buy the sheet metal? Then, woodzilla, what are you talking about "off eBay"? Is there some kink of insulation one can just stuff in around the liner "neck" where it passes into the chimney (the smoke shelf area)?
