Night and weekend burners...
Dustin
613
Western Oregon
In the continuing effort to heat my house using as little wood as possible, I have been burning only when I get home from work, and all night, letting the stove go out as I leave for work.
I burn all day when I'm home on my days off.
Living in western Oregon, it usually rises to 45 to 50 degrees during the day. When I get home from work, the house has usually dropped to about 60 to 65 degrees, down from the morning temp of 72ish.
No one is home during the day. Am I wasting wood loading this thing up, and letting it heat an empty house? It usually takes about 5 large splits for a full load in my quad.
Has anyone else tried this? Did you find you used less wood? Any issues with creosote due to one cold start a day?
Dustin
This is where a mini-split heat pump seems to have the advantage. Particularly if it is programmed to have the house warmed up when you return home from work, though I suppose a pellet stove can do the same if pellets are cheaper than electricity in your area.
If it only takes you a short time to heat your house back up to temp when you get home, than yes, there's probably little sense to keeping it going while you're out. If it's a chore to get it back up to temp, it's a good idea. My dad could get our cold house cooking in 20 minutes with his cast iron stove. I have a soapstone stove which is a much slower startup, but buys me an additional 4 hours or so of heat once the fire is out, so for me it makes sense to throw a few splits in if I'm going to be out for a few hours. Creosote speaking, I really don't think it makes a difference either way. Some would say steady burning in better than start/stop. Others would argue that, if you put some wood on, shut the air down and leave, it might smolder and burn below a safe temp and you'd never be the wiser.
I have been letting mine go out this time of year, but once the real cold sets in i go to 24/7 (my real cold is not near what some of yours is!!!). But this time of year even these colder days the coldest rooms are high 50s, and within a few hours i can have 1500ish sqft that we use up to 77ish in stove room from upper 60s and the bedroom about 65. SO for right now im letting it go out. Last year i think i was putting wood in and cutting the air way back and then opening it up again when i got home for another night burn. I have a cat stove so its not like im coaking creosote on anything but the stove interior. This way i can load once a day, but i have to use a full load in my 3.5cuft stove, but i can get 24ish hours out of it. The way im doing it now i have almost cold starts but think i use a but less wood doing it this way, just requires more work and fire building.
I load the stove up in the morning before I go to work. My goal is to keep the basement heated, for i find if i let the basement cool all day i am spending much too much time hearing the basement in the evenings. It was 21 outside when i left thos morning, and i have trouble justifying having the oil heat kick on all day when i know i can have the stove running for at least half the tome i am gone.
My wife and I both work weekdays so the fire goes out during the day. The house is down to about 60 sometimes when she gets home in the late afternoons. In really cold weather, like down in the high 20's or low 30's it takes quite a while to get it back up to a nice warm temp. So, if I had my druthers, I would keep a fire going all the time if need be. Starting a fire every day and taking several hours to get it nice and warm is a pain.
Tell me about it...... Me wife can maintain but not start a fire yet. I basically load at 11pm and load again at 7:30am and then again at 5:30pm. Keeps the house in the low to mid 70's. And by the way uses significantly less wood than starting a new one every night! That is very important there as I work my butt off for the wood and want every BTU I can get!
sounds like how i burn during shoulder season, I dont see a problem with this, your going to save money and its less hassle then making a fire in the morning and getting it dialed in before leaving for the day, why burn more wood to keep the house in the 70s for no reason?
For me its that load in the morning that I was not doing that caused me to build a fire every night when I come home, sucked! Before I would go through much more wood because things were left to go cold and I had to build a raging fire. I keep it at the upper 400's to mid 500's and it's nice.
Shoulder season I would burn to take the chill off by starting a new fire when needed. And even now it's not exactly 24/7 because if in the 50's no fire. My "main" heating source is hydronic and works quite well, once I figured that out.
I burn 24/7 . . . and do so even when I go to work and no one is home since our climate is quite different. If I didn't have a fire going when no one is home I would either burn up a lot more oil (we have our thermostats set to kick on the oil boiler at 60 degrees F) . . . or we would come home to a very cold home.
In your case . . . if the temps don't go down much past 60 or 65 degrees (which I find relatively tolerable) I wouldn't bother with a fire when you are out of the house . . . especially if it doesn't take very long to bring the house back up to temp when you come home.
I just let my stove go out when i am away and some times at night also and it ends up being about 62 when i wake up or get home. But it does not take long at all and not much wood to warm things backup.
+1 to the heat pump for mild climates.
or if you have natural gas just let that take over daytimes. Just burning weekends keeps my gas bill under $150/month even in the coldest of Jan/Feb - and I live in a very old, marginally insulated house with a fairly low efficiency heating system (steam). If I burned nights + weekends Id probably never see a gas bill over $75.
Dustin
We burn pretty similar to that except even if we are home we don't, as a rule, burn all day long, unless it's really cold.
I find we all appreciate the stove more when we come home to a cold house, like others we have a heat pump that we set for around 60 so there is no danger of the house freezing, but it can get chilly. That chill in the house is what eventually motivates someone to get a fire going in the wood stove, it's a very basic response.
Like a lot of people when we first got the stove we use to keep the house up around 78 F (26 C), but I don't think that is really healthy to live in a house that is that hot all the time, and as you mentioned, you go through a lot more wood.
Normally we let the fire go out during the day, even if there is someone home. Then at night when we start getting cold, or getting ready to go to bed, we'll get a good fire going in the stove and get the stove room good and hot, this makes you sleepy and chases everyone off to the cooler bedrooms, but not before making sure there is one more good load in the stove. During the night that heat migrates through the house (with the help of fans) and by morning the house is evenly warm and the stove will usually still have some coals in it and often my wife will toss a few more sticks in, but sometimes not, it just depends on how cold it is. Then we leave the house and let the fire (or coals) burn out, then the cycle starts all over again.
It is more work to let the fire go out and have to restart it again every day, but you do save wood, and if I was really concerned about saving work I'd just crank the Heat pump knob up a 1/4 turn and be done with it. ;)
I've found that those who tend to burn only nights and weekends also tend to have more creosote. If you could just add 2 or 3 splits for the daytime, even just to keep the flue temperature up, that could help with this problem. Of course, early fall and late spring are the challenges when it comes to wood heat. I also would rather just add wood to the stove rather than starting a new fire constantly.
Dennis- if I had your wood supply I would be reloading the stove every 15 minutes :-)
Ha! You probably have more wood than I do remkel.
At this point we burn 24/7.
Even though we have only a 1000sf ranch, I would rather keep it warm than play catch up every eve when we get home. We load it up in the am and damp it down so it cruises all day. Get home and its about 66-69 degrees.
We just sweep it if there is any worry.
I would invest in a bit of insulation. Those temps shouldn't require more than a few short time fires to maintain the house temps. Here when it's that warm the stove only idles or we are opening windows and we need to shut it down.
this is my first yr but i burn when I can so right now that weeknights and 24/7 on weekends... as far as keeping the fire going during the day Lately i have been throwing 3 spilts on in the morning while im getting ready for work and let them get going good then turn the air back half way when i leave, i have found it much easier to start a fire when i get home since i still have a nice warm to hot fireplace and coals...
My goal is just to reduce to amount of time my heat pump kicks on.. I keep the thermo set at 67
in a moderate house with about any woodstove of size and some insulation this should be no problem!
Right now we only burn nights and weekends. During the week after work maybe 1 - 2 nights a week for 3 hours. On weekends we will burn for maybe 15 hours straight each day. Right now with the questionable wood supply and having to use biobricks to supplement the wood, we are happy with what we can do to help keep the furnace from coming on. I find myself wondering what it would be like to burn 24/7 but that is not feasible right now
