Hello - this is my first post and I hope I have chosen the right sub-forum - apologies if I haven't. I have a Clearview Vision 500 cleanburning stove, and would appreciate some views on when wood is fit to use. We've been having lots of fun with the stove, using it to supplement our central heating here in London - our house has open fires but it was a lot of work for a little heat so we've fitted a stove in one open-plan area. My questions are:
1. As long as my moisture meter says it's under 15%, does it matter how old the wood is? I've been bringing in all the stuff I've been hoarding outside and leaving it indoors for a couple of days, but can't remember which of it is this year's fallen branches and which is older. Is it just water which dries out of the wood, or is seasoning getting rid of volatile oils etc too?
2. This may be a stupid question, but the answer isn't obvious to me.... is it OK to stack the next few logs on top of the stove to dry out before burning? I suppose there would be a fire hazard if left unattended, but with the stove pottering away at over 200C , my small logs dry out and split nicely on there. And I assume that the moisture released is quite a good thing to have in my room, counteracting the drying-out effects of the stove on the furniture! But... I think I remember reading not to do this, but no explanation was given why. Have Googled away to no avail, and would appreciate your thoughts.
Thank you very much in advance for your time.
Angela
Angela
