I have a VC Defiant Encore Model 2190 (with catalyst) that leaks smoke from between the flue collar and the back of the stove depending on the conditions (air pressure, draft, etc.). I am going to replace the gasket. While the stove is out, I place to inspect everything and make any needed repairs.
I have been using the stove for about five years, since we bought the house. I have had the chimney cleaned and a couple of gaskets replaced. It burns long and didn't smoke. But when I used it this year it was very smokey. BTW, I am in Maryland.
Also, looking in the stove I can see light (a little bit) from a flashlight coming in the junction between the flue collar and the oval-to-round adapter. There is a gasket between the back of the fireplace and the collar, but it looks like there is no gasket or cement between the collar and the adapter. Also nothing between the adapter and next piece of pipe. The installation instructions don't call for any cement or gasket after the flue collar.
Questions
1) Is it normal for the joints past the flue collar to have no sealant? Why does it not leak smoke, is it because of the draft?
2) Posts here indicate that these can be sealed with flat gasket. Should I do that even though it doesn't appear to smoke?
3) Is the flat gasket with tape any good, or should I use cement?
4) The catalyst has not been checked since we moved in. The manual says this lasts 2-6 years. I will take it out and look at it. How can I determine if it need to be replaced?
5) I am not going to remove the glass, besides that, it only uses standard rope gasket. Should I buy a set or several individual gaskets? Where is a good place to get a gasket set?
6) Screws and bolts. There are several screws and bolts that will need to be removed. If they need to be replaced, do I need special hardware?
Thanks,
Steven
Questions
Thanks,
Steven
