Hi All,
This is my first year burning a Hampton 300 wood insert. Just wondering how long on average I should expect to wait to heat the house? Are you guys getting the house nice and hot after about 4 hours burn time or is this after burning consistently 24/7?
I have a 2000 sq/ ft center hall colonial. The house is very well insulated; built 20 years ago; new energy efficient windows. The insert is located in the family room and at the other end of this room is the stair way to go up and beyond that is a doorway into the living room. We normally start a fire at night after work to take the chill off the room and then will be burning continuosly over weekend from Friday morning to Monday morning. Originally I was thinking I could crank this thing and get house up to 75; but now understand that it is heating by convection and pushing the air around the house may not be able to acheive this kind of temp.
I put a thermometer on the top of the stove where the fan air comes out (you need a flashlight to see it in there, but only place I could think of to get accurate reading). I will wait to get er up to 600 or so, damper down and turn the fan on high. This morning is about 30 -35 outside. House 60 up and down. After about 4 hours the room the insert is in is about 68, the rest of the downstairs is 65. The upstairs is only 61. Is this normal?
I'm fairly certain the install is good. I can damper it down all the way, glass stays clear and can hardly see any smoke coming out of the chimney. My only concern is the installer did not put the block off plate in properly. From reading this forum, I made sure to request this be done, even though the dealer said it was not necessary and to just block it off at the top. I saw the guys bring in a plate, but then got busy with work and did not get to inspect it before they put the insert in. Think it is worth pulling out the insert to have this checked out or are my expectations to high and not a problem at all?
Any input you guys can provide is greatly appreciated.
Thanks,
Chris
Thanks,
Chris
