Hello Gents,
I am new here so I will apologize now for any dumb questions...
Been trolling for a while trying to learn as much as I can to eliminate as many of those dumb questions as possible. Here are my details.
2000sq ft very well built house with R45 Attic, R30 walls, R19 floors currently heated with 4 ton dual fuel heat pump. Buying $400 a propane and electric bill averages $200 a month with 50 gallon electric HW heater.Heat Pump heat exchanger is rusted out after 17 yrs but air conditioning side of heat pump is still good. Thinking of putting in a outdoor wood furnace to squeeze another 5 yrs or so out of the air side of the heat pump, eliminate $400 propane and cut electric bill down. Also when I do buy another heat pump I can save $2K by buying a regular plain heat pump instead of a duel fuel propane heat pump. Wood furnace would be used for about 5 months out of the year during coldest part of winter, heat pump would be used Spring and Fall for mild temps. It was -5 last Tuesday morning on our mtn. I currently cut about 10 ricks of wood per year and have unlimited amounts of free wood that I enjoy cutting for my fireplace. I would still use the fireplace only for the looks, and not primary heat after installing the outdoor wood furnace. I also want to heat my DHW for further electric bill reduction.
1) My furnace would be approx 100' from house so 1" Urecon / Logstor pipes or 3/4"
2) I am thinking about a TN local made stove, " Hoss " 225 which is a smaller version of the Hoss 300. I think it has 225 gallons of water and probably around 200K BTU.
3) How big of a heat exchanger for my duct work, been told to get as big as I could to fill up the duct and keep the air flow good. How far in front of the heat pump does the HE go ? I have a package unit heat pump so everything is outside, then about 2 feet before it goes under the house crawl space. I have looked at HE on fleabay and even the same size comes in several BTU ratings I think depending on how many rows in the HE ? I think my 4 ton duel fuel unit is rated at 48K BTU on heat pump and 98K on propane @ 80% efficiency so how many BTU's do I need for my HE in the duct ?
4) When the insulated pex line terminate under the house and come up put of the ground do I go from there straight to the water heater or the HE in the duct work ? Do I put ball valves at the HE in the duct and turn it off during mild temps so I can only heat my DHW ? At the termination of the Urecon insulated 5" pipe to get to my HE in the duct and DHW do I use regular PEX and wrap with foam insulation from HD or Lowes ? My DHW heater is approx 40 feet from where the HE would be in my duct work.
5) Should I use a 20-30 plate HE for my DHW or one of the tube in a tube copper HE that are about 30" long ? I had heard that the plate exchangers have small channels and can get clogged up ? How would I mount either in a crawl space at my DHW heater, hang from floor joists close to DHW heater ?How do you insulate the HE ?
6) How deep to bury Urecon 5" OD pipe in TN and what else goes in the ditch besides thermostat wire and 14/2 for 115VAC wire for pump and light on side of wood furnace. I assume I would use 3/4" conduit to run electrical and thermostat wire in as well.
Many thanks and again sorry for all the questions fellas !
