jtp10181 said:Did they say why the recommended one over the other? Maybe the Regency gets the salesman more commission, and the Napoleon is easier to install?
BrotherBart said:One thing I would add Lil is if it comes down to a couple of stoves go with the dealer you are most comfortable with. It is hard to think of any "bad" stove these days. There is a dizzying array of good wood stoves being produced. So you are going to end up with a good stove and having a good dealer will make all of the difference. You will need some hand holding in learning how to use it and there is always a possibility of defect or problems with any new appliance and dealer service will be the key on the off chance that happens.
Keep us posted.
MrGriz said:BrotherBart said:One thing I would add Lil is if it comes down to a couple of stoves go with the dealer you are most comfortable with. It is hard to think of any "bad" stove these days. There is a dizzying array of good wood stoves being produced. So you are going to end up with a good stove and having a good dealer will make all of the difference. You will need some hand holding in learning how to use it and there is always a possibility of defect or problems with any new appliance and dealer service will be the key on the off chance that happens.
Keep us posted.
I saw a Vogelzang just the other day.......
lil pa said:hello everyone,
Just to update you on our decission we purchased an i2400 regency medium wood burning insert. It's to be installed the 17th of Oct and i'll report back once we start using it. we still have 85 degree weather here!
Again thank you so much for all your input.
Regards
Lil-PA
