(broken link removed)
Well here I am with some pictures, sorry they are out of order, I still have no idea why that happens.
Allow me to detail a little further on how I installed the chimney. The first step was to establish the location of the stove on the hearth. I then placed the interior double wall on top of the stove (making sure it was plumb), extended the pipe to the ceiling, and traced the outside. I found the center of the circle and drilled a small hole through the ceiling. I crawled up into the attic and found the hole in the ceiling, then used a plumb bob to mark the roof and drilled a small hole in the roof. Back down into the living room I cut a hole in the ceiling allowing a 3" clearance to combustibles. The class A chimney extended down into the living room roughly 9 1/2 inches, this was done to maintain combustible clearance of the interior double wall pipe. The whole chimney weight is supported from the roof. After the hole in the ceiling was cut I moved up into the attic again and cut out the hole in the roof. The roof hole is oval, having clearance of roughly 2 1/2" on the side with the brackets, and roughly 3" on the sides without the bracket. Now I had a hole in the ceiling and roof. I established the interior double wall pipe length and screwed it off. Then I placed the chimney sections on top of the interior pipe which allowed me to locate and install the roof brackets. I wasn't sure the 3 little screws in the interior pipe would hold the weight of the chimney (even temporarily) but they did. Now that I had the roof bracket installed I assembled the chimney and installed the locking bands between the sections. Then I plumbed the chimney from the outside and screwed the roof brackets down. Installed flashing, storm collar, and cap, and patched in to the roof.
I moved back inside up in the attic and checked my clearances against the roof and at the ceiling again. I then started building the attic insulation guard. For this I simply framed up from the ceiling joists and tied into the rafters above forming a box around the chimney. I cut some wonderboard and screwed it to the little frame, making sure to alternate sides so the enclosure towards the chimney would only be wonderboard. In other words, the frame sits on the outside, wonderboard on the inside. I applied some aluminum furnace tape along the seams for good measure, not needed necessarily, but just to keep the dust out of the insulation guard. Also, I have some blown in insulation under the bats, and didn't want any of that creeping in. You'll notice that 2 sides of the wonderboard are taller than the opposing two, that's because the edge sits on top of the ceiling joists, so they are 6" taller than the other sides. I could have cut it down, but decided against it.
I've also included a few pictures of the poker and rake I made. Quick and dirty, but effective. Another photo of the hearth, with my new ash can, and log holder. The log holder is a steel army cargo box (not sure what era) and works perfectly to hold logs. Had it lying in the garage for years... I knew I would use it for something eventually.
That's about it, sorry for the long post. If anyone has any questions or comments please let me know. I want to make sure this is all safe.
-Kevin
-Kevin
