First off Happy New year and thank you for the wealth of information !
I've been pouring through the archives and Q&A section looking for some guidance on a new source of heat for our new home. We moved into a 10 year old 2600 sq ft colonial with an unfinished basement , as you can imagine its a burden to keep warm. I've burned 450 gallons of oil since sept...NFG!
It's currently being heated with an oil fired boiler Via baseboard heat and hot water through a 41 gallon boilermate. I have been running a Jotul GZ 550 DV (L.P.) with the blower on as a supplement .
I'm considering a Greenwood http://www.woodstoves.net/greenwood/greenwood100.htm boiler in the basement to handle all the heat and hot water needs, the drawback is the initail purchase price and handling 2000 lbs safely into the basement through the bilco doors.( Small excavator?) This unit would also heat the garage I reckon...bonus points there!
The cheapo in me wants to just put a nice wood stove in the living room and be done with it...this does'nt adress the hot water needs though. (also goes against the wifes desires) I'm not sure how much oil I'd burn only supplying hot water but at the price per gallon i really dont want to burn ANY! Time is money...time I can burn,money not so much.
Then there are these units http://www.wood-burning-boilers.com/model 500.htm would a wood stove with a boiler jacket be a compromise or a happy medium? I have no problems cutting registers in the floor to facilitate heat movement but reading through these forums the basement walls (un-insulated) would soak up alot of the heat.
Lastly I'm considering getting a bigger wood stove http://hudsonvalley.craigslist.org/app/4209412991.html in the basement and fabbing a serpentine coil off the back for hot water. Adding a storage tank and the plumbing might be a wash vs. buying a new unit?
When I'm not obsessivly stalking heating systems I'm an Ironworker by day and Mechanic/Blacksmith/Plumber/Carpenter/ Tractor enthusiast/Redneck in my free time...Like I need an excuse to buy a bigger chainsaw![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Any help is greatly appreciated as I'm kinda stuck here freezing by the space heater!
Joe
Joe
