New Wood Stove
snipersdad
4
So I bought this great wood stove and am hoping someone here my know how the brick pattern inside may go. The original bricks are pretty broken up. The stove appears to be older but here is the information on the tag.
Looking forward to getting this started up I may actually be able to heat my whole house finally
The Frontier Model L
Serial # 8A00123
  • New Wood Stove
Do you think the over firing has damaged it?
Doubtful. Frontier stoves were very very heavy duty.
As far as the bricks, you will probably have to just mess with them until something works. Keep in mind that the bottom ones don't have to fit tightly at all - you can use sand or just let it fill with ash in-between them. Same goes to a degree on the sides - not a big deal if they don't fit tightly.
Also, in case they are so broken up that it is not obvious.
I'd put the sides in first, then the bottoms. That way the bottoms support the sides and keep them from kicking out.
Reactions: snipersdad
Thanks guys the advice is great. I will keep looking to try and find a diagram that will show it. Ive never had bricks in a fireplace. My other one was so small it didnt have them
Many of those stoves have retainers for the tops of the firebrick, to keep them from falling inwards. Generally it's just a thin piece of metal bent like an inverted "L"... If yours does has the retainer(s), that will tell you whether or not the bottoms go in first, or the sides do. If there are no retainers, do like pen said...
