Hi all. I'm looking into replacing my existing wood insert with something larger. Ultimately the goal is to extend burn times to get through the night with at least some heat being output in the morning. I'm leaning towards a Blaze King of some sort, but I was hoping to get some ideas and/or feedback on some other options before just jumping into the BK.
My current stove insert is an Avalon Rainier. I don't have any real complaints about it and the output is more than enough to keep up with the coldest days around here. The only problem is the small (~1.8 cu.ft.) firebox and generally only burning pine** means that I can't quite get a full night out of a full load. I normally set the damper so it's just shy of closed, and at best I will wake up with enough embers to get it restarted without resorting to matches. Unfortunately that means the stove had long since ceased providing any meaningful heat.
The stove is located on the main floor (~1000 sq.ft.) and I generally run it all winter. The pellet stove in the basement runs 24/7 in the winter and picks up the slack when the wood stove runs out of fuel, although that heat doesn't do a great job of reaching the master bed/bath. Electric baseboard is the backup heat and usually powered off unless we are going away for more than a day.
I've been reading a good amount on this site, and it seems like Blaze King keeps coming up whenever someone is concerned about long burn times. I'm sure that I won't get anywhere near the listed burn times with pine, but a consistent fire for even half of the rated time would be more than acceptable. I am curious though, is there any other insert out there that even comes close as far as burn time? I'd probably just go for the BK, but they are pretty spendy and none of the dealers near me even have anything on the floor to check out (inserts at least).
** Pine is pretty much all I can get around here. Mixed hardwood goes for $300+ per cord. That's hard to justify when I've got several years worth of free pine without even stepping outside of my 2 acres. Probably a lifetime free supply without leaving the neighborhood.
![[Hearth.com] New Wood Insert - Longest Burn Times? [Hearth.com] New Wood Insert - Longest Burn Times?](https://www.hearth.com/talk/data/attachments/248/248093-ff299fd73c773a618f8181c855fada29.jpg?hash=UMFpVGDnvM)
![[Hearth.com] New Wood Insert - Longest Burn Times? [Hearth.com] New Wood Insert - Longest Burn Times?](https://www.hearth.com/talk/data/attachments/248/248094-9a2e2925c19180dffdbe278f28537a94.jpg?hash=I7WEWQmR52)
