Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I've got a Hearthstone Phoenix stove, still working on installation, my question is inside the stove, on top of the airwash tubes there is a piece of white insulation of some kind. What is that and what is going to keep it from burning up?
As stated, this is a necessary component of your stove. All modern EPA certified stoves that use this method (as opposed to the "downdraft" type stoves) to burn combustible wood gases have a "baffle" in the top of the stove made out of some type of special material. My stove uses a combination of refractory fire brick and steel. Basically the baffle forces the smoke to take a less direct route to the chimney. While the smoke is collected underneath the baffle, preheated secondary combustion air is "injected" onto the top of the fire by the burn tubes, causing the wood smoke itself to combust and burn. This gives you more heat and a cleaner burn. As you load your stove, take care not to hit the baffle with your splits, as this will extend its life somewhat.
The above posts are 100% correct. I just wanted to say congrats on buying a great stove. Of course, if there is no photo, theres a 50% chance you dont have that stove at all
Well as long as it isn't a piece of styrofoam that the woodstove shop stuffed into the top of the stove since they didn't have any better place to put it, I think it would be safe to say you'll be OK since this is (as mentioned) most likely an integral part of the secondary burn technology -- either the baffle board (or baffle board and insulation blanket like some models have). Both the baffle board and insulation blanket (if the Phoenix has one) are fire proof and both are important to keep things working.
Incidentally, welcome to the forum . . . and where on the Kenai are you located? My sister and her husband live in Portage . . . almost across from Big Game Alaska (well they have a new name for it now . . . can't remember the exact name.)
Pagey - I've been on this website for a little over a year and every once in a while I find a post that really explains certain things perfectly.Yours is one of those posts.
