- Jun 12, 2006
- 1,053
Hi -
Thanks everyone. Y'all have bene very free with the advise and encouragement. I first psoted a question about re-installing an old 1983 Insert :red: this past spring. Much lurking and learning.
I ended up buying a VC Resolute Acclaim. Then I carefully cut though the existing Heat-a-Lator steel fireplace box, built wood scaffolding, a 4' brick chimney extension, Rigid 6" liner with insulation, and an additional 3' Class A pipe at the top about 18" total. I also extended floor protection 18" in front of the hearth. I've still got to lay some Marble on there.
The Inspector said he'd not seen a nicer install. He measured a couple spots, reviewed my digital pic's, UL documentation and that was it.
It works great even in warmer weather the air is very responsive to the damper. For cleaning I can remove the Class A pipe to clean on the roof without a ladder.
Question to Acclaim owners: What temps do you like to see at the griddle? I really start seeing major heat production at around 500-550. What range do you like to operate in? I'm burning mostly Ash and Silver Maple.
Thanks again for helping guide me to the warmth and light!
Mike P![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Mike P
