Pretty neat new window ac design by Midea. Its basically a scaled down mini split. They just were awared an Energy Star 2020 most efficient appliance award. You can preorder the 8k for $279 right now. Compared to window units that run full speed on or off these things are going to offer some substantial savings. You can also open and close the window with the unit in place.
Here is some technical info they provided when I emailed them
We have confirmed that the units will modulate down to 2k BTU. At that condition the units will pull roughly 120W.
Based on the algorithm we use (that closely follows our mini-split algorithm) it is more common for the units to spend time operating slightly above that 2k level. For the respective 8k/10k/12k units the consumption at that capacity is around 147W/171W/190W. Let us know if you have any other questions!
![New u shaped design window ac with an inverter. New u shaped design window ac with an inverter.](https://www.hearth.com/talk/data/attachments/257/257693-abaab318ead046f37dd21db79d15b0f5.jpg)
![New u shaped design window ac with an inverter. New u shaped design window ac with an inverter.](https://www.hearth.com/talk/data/attachments/257/257694-dd6c6a108c0cb5f0b69a21b981cf9154.jpg)
