I have a bunch of trees that I want to take down along a road. The area is sloped and the trees all lean towards the road. After a few unplanned drops into the road I decided I needed to rope these trees so they land away from the road. The woods are dense and getting a extension ladder to get a rope high enough would be major a PITA. I picked up one of these rigs Amazon product ASIN B075VYX31BBasically an industrial strength Wrist Rocket on a pole designed to launch a throw bag with a light line up high in a tree over a branch. The throw weight drops down to the ground and then is used to pull a large rope up into the tree. I then put a loop in the end of the big rope over the other end of the big rope and pull it up until it tight. The end down near the ground gets run to tree where I installed a power pull (I am doing this solo). Getting the rope up high in the tree really helps as it requires less overall tension then tying low on tree. I then notch the tree I am cutting, snug up on the rope with the power pull then make a final cut. The trees drop away from the road.
Its not a fast process but beats having a tree drop on the road. Luckily its a rural road so not a lot of traffic.
A few cautions if someone is considering. The one I picked up came off of Amazon Warehouse, it does not have a trigger. It works but the more expensive version with a trigger would be easier to use. The other caution is this is not a toy, its can shoot a throw weight with line attached to it 150 feet in the air. I am dropping trees prior to them leafing out. My guess is with tight canopy and leaves will take several tries. The rig does not come with the throw weight or the throw line.
