Hi everyone, I've never had a fireplace at all before so I have no idea what I'm doing and my questions are probably incredibly basic, but I recently moved into a house with a fireplace, and after playing around with it for awhile I eventually discovered that the black part (which I later learned is called a "fireplace insert") of it can actually be removed from the white part. And then I got to see all the cool bricks behind it. So that was all pretty amazing to me. I'm not sure what it would have actually burned in the past, maybe coal?
There were broken black tiles on the hearth when I arrived, and this additional long piece of cast iron something that just sat there pretty much spanning the entire width of the hearth. I don't have a photo at hand of that piece, but can get one if anyone is interested. The tiles hadn't even been grouted (?) in properly and the spacers could still be seen. I removed the tiles and now there's what seems to be just a layer of cement with a texture on the top.
Originally I was thinking I would just polish up the insert, do something with the hearth (still not sure what), then stick the insert back in and just have it look nice but not actually use it. But then I started wondering if a wood heater would be a good idea. I have always wanted a useable fireplace of some sort.
I've attached some photos here, and I took a few measurements too. I would be really appreciative of any information or suggestions, particularly in relation to the following:
1) should I just put back the original insert, or should I put in a wood heater
2) if the latter, should it be an inbuilt one or a freestanding one (if this would even fit)
3) any ideas for the hearth (should I tile it, or put a slab of granite there, or just paint it with that heat resistant black paint)
Here are the measurements (in cm) so far, however I can get more if it helps:
660 deep total
200 deep hearth
760 wide inside firebox
1250 wide hearth
I've tried to attach some photos, hopefully it works! Thank you in advance for sharing your knowledge and experience. Please remember I'm starting almost completely from scratch and know close to nothing about the subject![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
![new to the whole fireplace thing new to the whole fireplace thing](https://www.hearth.com/talk/data/attachments/313/313355-256ddaaca1cc6347596db3afe16263e6.jpg)
![new to the whole fireplace thing new to the whole fireplace thing](https://www.hearth.com/talk/data/attachments/313/313356-24f1ffdce0210cd56ede4f4904d3fc14.jpg)
![new to the whole fireplace thing new to the whole fireplace thing](https://www.hearth.com/talk/data/attachments/313/313357-add946305156e044288eba3e9d0992c6.jpg)
![new to the whole fireplace thing new to the whole fireplace thing](https://www.hearth.com/talk/data/attachments/313/313358-3a9029a34ba0fa1703dd723862a516ab.jpg)
660 deep total
200 deep hearth
1250 wide hearth
