- Mar 4, 2013
- 22
I live in Maine and I was told by a friend about Hearth.com here I am.Welcome. Gives us an idea of where abouts you live and that should help get the info you seek.
I have only looked at the ones and Home Depot and Lowes. I bought a couple of bags from Home Depot Green Supreme.Wood pellets would be your best choice!!
Just kidding, Welcome to the forum...What brands do you have to choose from??
I want to find the best pellets with a high BTU, not a lot of ash, clean and also at a good price.
Westbrook Maineok next question , where in maine ? sorry but it's a big state and will make a big difference in what is available and where . lots of mainers here btw
If you want suggestions to start with
Stay away from Infernos
These are what I have found in the area:
- HD: Look for Fireside Ultras, they have burned hot this year but a bit ashy.
- Lowes: Greene Team if they not selling above 220/ton
- WalMart or TSC: MWP blend: again good heat and a bit ashy
- Upper end from pellet houses: Spruce Pointe, North Country and Vermonts (these tend to blacken the firebox: but top shelf pellet) are all super hot, low ash and very clean...but expensive. MWP Soft have been very hot but more ash than the previous 3 and a bit cheaper too.
Well for starters pick a nice low ash one and get a few bags and try the stove out.
You might want to do a search on here for baby countryside and wade through the threads.
Welcome to the Forum.
As Smokey said, do a sesrch here on the Baby.
How long have you been burning in it? How often do you have to open the door and intervene because the pellets are piling up?
Depending on the age of the stove, and whether it has the High CFM combustion blower and Pellet pot (Cast iron and thick, the corn pot is then and stainless, and needs Mod'd if thats what you have).
My buddy's Baby burned like chit. Needed to open the door every 12 hrs or so to empty some pellets.
After a fee little things, he can go a week without opening door or touching the stove (as a pellet stove should be).
There is insufficient airflow to the pellets, you shouldn't have to touch that pot every 12 hrs. You should be able to just ooad the hopper and not worry about the pot.
Again, search your stove title. My Best Friends heated well, but needed to mess with the pot. After a simple Modification, he can not only go longer between cleaning, but also gets more heat. More air through the pellets gives you a hotter fire, more complete combustion, and goor foy ash ejection
Here is a video on his burning after start up. Notice how active his flame is and his damper is about 50% closed. Without proper air, your pellets are not fully burning and your not getting the efficiency you should. Plus you have to babysit it twice a day, and that ain't fun.
There is a High flow exhaust blower that Magnum sells to fix this (because they know its an issue) and also using the pellet pot instead of the corn pot. Which pot do you have? Stainless pot with holes up both sides, or cast pot with holes in the bottom?
Thanks I will try that. I will also tell me friend about this too. He has the same issue with his ash. Any other hints or ideas for the baby magnum.Little black Rat turds are unburnt pellets.
I wouldn't drill the holes any bigger, but close off the top row or two on the front and back of pot
Holes that High up are not needed. The air that would normally flow through the upper holes, will be forced to travel through the lower holes and be use to fully combust the pellets and eject the ash from the pot. Giving you the option to just keep filling the hopper and not worrying about pellets building up and causing a Hopper fire
High temp foil tape on the non Fire side of the pot and/or furnace cement rated for 2,000° is a good start.
My buddy, member Jrsdws and also CWR all have done this mod and it works well. Also cover about 50% of your air wash. Take the foil tape or reg aluminum foil and.cover 25% of each side of the air wash (little slit just in front of pot, that goes across the windows length). This will provide even more air to the pellets.
Where can I find the correct high temp foil tape?Little black Rat turds are unburnt pellets.
