Hello to all, hope this is in the right section and you all can help help me make the right decision.
I have an existing fireplace with a heatilator and a straight vertical rise of approx 25ft. I started shopping for an insert and came across a:
Whitfield, Model Profile 30 Ins-2 . The owner says he used it for only 3 seasons. It includes the brass trim surround, approx. 25' of stainless steel 4" flex pipe and "T" 90 degree with cleanout for chimney liner. (States the Liner needed for proper stove draft.. I will get back to that later.) A Cougar ash vacuum , special vacuum, designed for pellet stoves. Allows you to vacuum hot ash and Approx. 35 bags of low ash pellets.
He is asking $1700 just for the stove or $2000 for everything. I really do not want to get taken here as I no nothing about pellet stoves so I really hope you all can help me out. Is this a decent deal? Should I just buy a new insert from Homedepot for less or about the same cost? I think this stove is discontinued and I have read some issues from this stove from bad bearings to weak auger motors etc. But it does state is a model INS -2 so I assume the 2 is 2nd gen and how is it better then the 1st and why? Is it still a poor design or is it a good stove?
I want to go check it out in action tomorrow night. He says it is for sale because they sold the house but it is still install and he uses it.
Ok maybe getting ahead of myself but according to the pdf on lennox website http://www.lennoxhearthproducts.com/resources/manual/775023M Rev E-Profile-stoves(II&OP
.pdf
Page 17, that I can go up a min of 18" above the existing damper and as long as I seal the joint and my masonry chimney is in good order that would be enough. Is this ok? my Chimney is only 8 years old and has a proper cap...
Thank you all in advance.
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
