Hello,
This is my first Pellet Stove and I recently got a used Quad Santa Fe that hasn't been used in about 5 years. Unsure of the model year, but I did give it a brief go over by removing the baffle, vacuuming in that area, using the cleaning rods until no more ash was being dumped then breaking up any additional crud in the heat exchangers. Then I vacuumed the blowers, intake, exhaust, cleaned the fire pot as best as I could with a putty scraper. I put new fire rope in between the two bricks as well. Not sure if it was needed, but figured it can't hurt.
The unit works well, however the fire pot cleaning rod gets stuck sometimes and simply pushing on the plate from the bottom with ash pan removed can get it to move back. I noticed if I spray a little pb blaster on the pivot points it will snap back on it's own for a while, but problem returns. I want to take the fire pot out and soak it in hot water (as I have read in some other threads) to really ensure getting it clean as well as regreasing the pivot points with some high temp red wheel bearing grease.
Removing the fire pot seems easy enough, however should I hold off until I get a new fire pot gasket? I am unsure if disturbing it after 5 years will cause a problem. The gasket is cheap, so I ordered it anyways, as well as a new tadpole gasket for the door and thermocouple gasket. All OEM parts as it appears the pellethead brand parts have problems (particularly the reviews for replacement thermocouples!).
